The Esri Linear Referencing REST API samples, depicting tasks such as MeasureToGeometry and GeometryToMeasure are super powerful. The samples use an older version of the ArcGIS API for JavaScript, v2.7; however, exchanging the script tags for v.3.41 is painless and the examples still work. Although ArcGIS API for JavaScript underwent a major overhaul from v3 -> v4, such that the examples would need to be updated to become v4 compliant, would the Linear Referencing REST API still work if the Linear Referencing web service was published from ArcMap? Does the Linear Referencing REST API only work with v4 of the JavaScript API if the web service is published from ArcGIS Pro? Thank
