Does anyone know if it is possible to insert a # of vertices to a line programmatically?
Basically what I am looking for is a script/code that will take a variable # (from a field I calculate) and insert that many vertices to the line -- placement isn't too important at the moment.
In my case:
I have an area, and within that area I might have 4 lines. I need each of those lines to have the same number of vertices. I have a model that will iterate through my features, find the line with the highest vertex count, store that number, then calculate the difference for the other lines.
Basic example:
Line 1 has 100 vertices. Line 2 has 95 vertices. The model will calculate a field to say that Line 2 needs "5" vertices to equal 100.
Then I need to find a way to insert 5 vertices to that line.
I have thousands of lines I need to do this for, so manually right clicking, and adding a vertex is not a solution. Also, Densify doesn't suit my needs either.
I did see this thread on stackexchange - arcgis desktop - Adding vertex set distance from first or last vertex in polyline? - Geographic Information Systems Stack Exchange
but not sure how or if that could even be modified to do what I am looking for.
