I created a simple model to delete all records from a hosted feature layer in AGO (truncate tool) and then run the Update Features With Incident Records tool to repopulate that feature class with data from a SQL server database. On creation of the tool it worked fine and I also have another model almost identical to it which also works fine; however, every time this tool has attempted to run since it gives the warning "None of the processes are ready to run." even though the entire model has been validated. I found one other post with a similar issue, but the resolution on it did not apply to my issue. Any help would be greatly appreciated.
I have also noticed that if you double click on a tool in the model builder it no longer opens the tool on this specific model, though I am unsure as to why this is the case.
Any help would be greatly appreciated!
