I've created a notification flow for my ArcGIS Field Maps collection events using Integromat. The actual notification employs the Microsoft 365 Email (Create and Send a Message) module.
Custom HTML has been applied to the Body Content portion of the email calling out essential information extracted from the attribute information collected in the field. One of the HTML sections contains retrieving the Date from the collection event. The date, while accurate, will require a bit of HTML formatting to make it a little more user friendly.
The current HTML code is as such...
<b>Date</b>:
{{7.attributes.PresentDate}}
<p></p>
I've also attached two screenshots...one illustrating the actual module and another detailing the data and time format currently being supplied.
Can someone please take a look and provide some valuable HTML code modifications to change the date to mm/dd/yyyy? The time component at the end is really not necessary at all as well.
Thank you so much for your time in advance!
Jeff
