Hi. We have an ArcGIS Server map service with feature access enabled. The service was published through ArcGIS Pro and metadata was added using the map metadata viewer prior to publishing. The metadata appears in the service description through manager, the rest end point, and the Portal (we use that too) item details for both the map service and feature service.
We use ArcGIS Pro (2.9.2) to view the map service and feature service. However, when viewing the metadata (after adding the service to a map), the metadata is empty for the feature service. It is complete for the map service.
Is there something we are missing when adding metadata to the service?
Thanks.
