I'm testing the Address Data Management solution and plan to deploy it as soon as I have a solid grasp. The issue I'm having currently is with the Full Address Number that is auto generated in one of several different ways. No matter which method I use, the generated numbers are not in line with the actual numbers. Which means this isn't much of a timesaver if I have to go back and edit each one after I create it.
I've tried using the Offset on Left/Right Side of Road and the Address Line Method. The first address I create is generally two to four digits above what I have as my first From Address on my center line. Then gets progressively more out of sync as I go along. Is there anything I can do to make the numbers match up better?
Respectfully,
Chris M.
