I made a test map with ArcMap 10.8.2 I added two layers. When I select one of the layers in the Table of Contents, right-click and Zoom to Layer, that layer appears. When I select the other layer, the previous layer disappears and the newly selected layer appears. Any idea why I cannot see both layers at the same time?
======= Layer 1 below ==========
Data Type: Shapefile Feature Class
Shapefile: E:\map\GPS (new map for GPS)\shapefiles and tif files\CLIPPED FILES FOR NORTH_Zone_15N\CLIPPED FILES FOR NORTH_OHN_WATERBODY.shp
Geometry Type: Polygon
Coordinates have Z values: No
Coordinates have measures: No
Projected Coordinate System: NAD_1983_UTM_Zone_15N
Projection: Transverse_Mercator
False_Easting: 500000.00000000
False_Northing: 0.00000000
Central_Meridian: -93.00000000
Scale_Factor: 0.99960000
Latitude_Of_Origin: 0.00000000
Linear Unit: Meter
Geographic Coordinate System: GCS_North_American_1983
Datum: D_North_American_1983
Prime Meridian: Greenwich
Angular Unit: Degree
======= Layer 2 below ==========
Data Type: File Geodatabase Feature Class
Database: C:\Users\PCs for People\Documents\ArcGIS\Default.gdb
Feature Class: Q_Campsites_Jan2022_Zone15
Feature Type: Simple
Geometry Type: Point
Coordinates have Z values: Yes
Coordinates have measures: Yes
Linear Unit: Meter
