Is there a preferred way to calculate a field?
I calculated two fields separately in a table in SQL via the Geoprocessing Tool ‘Calculate Field.’
Seems ridiculous to me with the processing power available that it takes 45 minutes to calculate 45K rows of 1 field with a simple conversion from a double datatype to text.
I would understand if I were calculating Einstein’s Theory of relativity on every cell.
I performed the exact same calculate with the same feature layer and data but in a File Level GDB on a file server residing 20 miles away.
It took 11 seconds!!
If my math is correct, that’s 24,545% faster.
The only thing removed from the equation was SQL. What gives? Any help or suggestions?
