Hi all,
I am trying to achieve exactly what is described here (For example, a building scene layer can be shared with an inspections table. You can edit inspection information on a building and view this information in real time across the organization.) but I cannot seem to get the relationship class to persist to the web layer. The relationship class works as expected in the file gdb (multipatch > standalone table) but after publishing (either publish as web scene or select the layers and publish as web layer) the relationship class does not show up in the layer definition. I am not seeing the table as a layer in either the hosted feature layer or the web scene layer although I can see it at the time of publishing:
Any idea what I might be doing wrong? The end-goal is to have users select a feature in a 3D web scene and launch a Survey123 form via a pop-up to populate a related inspections table.
Thanks in advance!
