I've seen a few similar posts about this but am still having issue with figuring this out. I have a model builder that I want to use to 1) process a feature layer, 2) replace an existing web layer in ArcGIS Online, and 3) automate the entire process.
I am having most issues with the second step: replacing an existing web layer from ArcGIS Pro to ArcGIS Online.
I've tried to piece together a tool using a python script using the following (just a few resources I've come across):
https://learn.arcgis.com/en/projects/automate-updates-to-web-feature-layers-without-scripting/#create-and-schedule-a-model-to-automate-updates
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/server/an-overview-of-the-publishing-toolset.htm#ESRI_SECTION1_3A66E57F2C604C0C85F648C8746B1E69
https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/publish-and-overwrite-web-layers-in-modelbuilder/
If anyone has created a tool that does what I am looking for, would you mind sharing your process or how you came to your final output? I'm not sure if I need an admin account to do this or if I'm maybe missing something in my script.
