I am experiencing intermittent pypyodbc server connections. I am able to successfully run a simple query on a SQL Server database, and without making changes, the same query won't work 5 minutes later. Any help would be appreciated.
-JC from Boston
(Update: When looking at the debugger, I got an error regarding "Trying to use a closed connection")
(Update: I believe the problem is arising with numerous open/close connections strings in the program and then running certain lines when the connection is inadvertently still closed.)
