Modifying .rbj in ArcMap Desktop Advanced 10.8.1 - Geometry on Geometry check, looking to find points not within areas. When the entire .rbj is run, that check flags points that are within the polygon, seemingly ignoring the "Not" box that is checked in the check parameters. When that same check is run singularly, it does not flag any, as there are none such errors in the .gdb.
