I have a hosted feature, with two related tables, in Portal 10.8.1. Since I'm unable to perform in-memory joins in ArcMap or Pro, to then publish to Portal, and our version of Portal (10.8.1) does not have the "Create Results as hosted feature layer view" option, I turned to AGOL... I created a map and added the feature to the map via Add layer from Web, entering the rest URL of the feature in Portal. From there, I attempted to join the feature to one of its related tables. I can perform the join, but the "Create results as a hosted feature layer view" option is grayed-out, and I cannot select it.
This would be fine, if I didn't need to have the join view update whenever a new record was entered.
Any ideas of why I can't create the view (is it because the hosted feature doesn't live in AGOL?) or any ideas of how I can create a live, joined view of the data?
