I'm trying to develop a geoprocessing tool for handling mosaic datasets. Using ArcGIS Pro - I can query a mosaic dataset and find how many primary rasters it contains. How can I replicate this behavior in a script? If I had a normal feature class I would make it a feature layer, select on the layer, then GetCount() to find the number of rows.
How would you do this with a mosaic dataset that contains primary and overview rasters?
def query_primary_rasters(input_md):
""" Return the number of primary rasters in a given Mosaic dataset
arcpy.AddMessage(f"Input Mosaic Dataset:\n{input_md}")
query_by = "Category = 1" # primary rasters
md_lyr = "md_lyr"
# arcpy.MakeFeatureLayer_management(in_features=os.path.join(input_md, "Footprint"), out_layer = md_lyr, where_clause= query_by)
# arcpy.MakeMosaicLayer_management(input_md, out_mosaic_layer= md_lyr, where_clause= query_by)
# NOTE - below works but doesn't return selected row count (includes all items)
arcpy.management.SelectLayerByAttribute(input_md, "NEW_SELECTION", query_by, None)
count_primary = int(arcpy.GetCount_management(md_lyr)[0])
arcpy.AddMessage(f"There are {count_primary} primary rasters in the mosaic dataset")
return count_primary
update_md = arcpy.GetParameterAsText(0)
query_primary_rasters(update_md)
