Let's say I want to merge two datasets together. Both datasets have a huge number of fields, but I only want a handful in my output, and they need to be manually mapped from the input as the names are all different.
The intuitive way to go about this, to me, is to select all the existing output fields and delete them right away. Sure, there's some I want to keep, but I know I'll be renaming and so on. Plus, they're hard to find since there are, like I said, a ton of fields. However, when you delete all the existing output fields, the option to add an output field goes away.
Here's before - with all the fields loaded in:
Note the '+' in the Output Fields column. When I select all these fields and delete them, the '+' goes away:
The only way to conjure up the '+' again is to hit that Reset button, which adds back all those fields I didn't want. The workaround - which is not very intuitive - is to delete all but one field, add your fields in, and then delete the remaining original auto-generated field.
My suggestion is here is to have the '+' persist.
