Hi all,
I have written code that selects rows of a buffer shapefile based on that file's intersection with a polygon that represents the extent of a raster. In the photo below, the code selects all of the red dots for this given polygon.
Using a cursor, I am going through those selected buffers and clipping an associated raster by each buffer. The code below was working when I wrote it three months ago; however, since updating, I am having a problem grabbing the SHAPE@ token as a polygon to clip the raster. EDIT: I would have been using Version 2.8.3 when I wrote and ran the code successfully, and I have Version 2.9.1 now.
I believe I've isolated the problem to the row[1] command. Previously, I'm under the impression that I was grabbing a polygon object. Now, however, my output for the lines,
print(' row: ', row)
print(' row[1]: ', row[1])
is showing row[1] as two different outputs, a Polygon object that I want and the geoprocessing geometry object that it now gives me:
row: ['LCRas_0', <Polygon object at 0x1f56ab62108[0x1f56db53300]>]
row[1]: <geoprocessing describe geometry object object at 0x000001F56DB53300>
The clip code that once worked is now giving me a blank output. I've also tried Extract by Mask, but receive an error (good ole 99999) when I try to specify that the output extent should be that of the buffer.
Could this be a bug in the versions, or am I missing something simple? Thank you for any input!
env.workspace = r'I:\test\Polygons'
arcpy.env.addOutputsToMap = False
fields = ['RasterName', 'SHAPE@']
j=0 #code was made pieacemeal to work on 3 comps; number changes depending where in the shapefile you're at
buff_file = r"I:\test\test_buffs.shp"
for poly in listp:
#record lc file that corresponds
lc_file = poly[:-9].replace(" ", "")
path = r"I:\test\Classified"
cor_rast = os.path.join(path, str(lc_file+"_classified.tif"))
raster_xmin = arcpy.GetRasterProperties_management(cor_rast, "LEFT")
raster_xmax = arcpy.GetRasterProperties_management(cor_rast, "RIGHT")
raster_ymin = arcpy.GetRasterProperties_management(cor_rast, "BOTTOM")
raster_ymax = arcpy.GetRasterProperties_management(cor_rast, "TOP")
extent = raster_xmin[0] + " " + raster_ymin[0] + " " + raster_xmax[0] + " " + raster_ymax[0]
print('Starting arcpy.da.UpdateCursor')
with arcpy.da.UpdateCursor(arcpy.management.SelectLayerByLocation(buff_file, "INTERSECT", poly),fields) as cursor: #select by polygon
for row in cursor:
rname = str("LCRas_" + str(j)) #make raster name
path = r"I:\test\Rasters" #set path where raster output will happen
rpath = os.path.join(path, str(rname+".tif")) #create name of raster file
print(' Starting arcpy.Clip_management for ', rpath)
print(' cor_rast: ', cor_rast)
print(' raster_xmin: ', raster_xmin)
print(' raster_xmax: ', raster_xmax)
print(' raster_ymin: ', raster_ymin)
print(' raster_ymax: ', raster_ymax)
print(' extent: ', extent)
arcpy.Clip_management(cor_rast, extent, rpath, row[1], "0", "ClippingGeometry", 'MAINTAIN_EXTENT') #extract raster from land cover
print(' Ended arcpy.Clip_management for ', rpath)
row[0] = rname #set row to equal raster name
cursor.updateRow(row) #updates row to have raster column
j=j+1
print('Ended arcpy.da.UpdateCursor')
P.S. I am cross-posting this on GIS stack exchange and will share any updates if I get them there as well.
