Hi, I'm attempting to use append to add data from one table to another, but I am getting the below error (I am writing this in a script, but have tested the append tool in ArcMap as well with the same error):
File "C:\Users\zieglerhm\Documents\ArcGIS\Projects\CW2020_IRP_DataProcessing\Script\WorkSummaryDataImport_v0.2.py", line 184, in <module>
arcpy.management.Append(gm_reh_sum_mem, gm_reh_sum_target, "NO_TEST", gm_reh_sum_fldmap, "Mechanical Cleaning/Root Removal")
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 3995, in Append
raise e
ExecuteError: ERROR 001156: Failed on input OID 1, could not write value '' to output field REHABLENGTH
Failed to execute (Append).
The problem is that the field in the source table is of type string while the field being mapped to in the target table is of type double. I was under the impression that field mapping would automatically convert to the new field data type, and the following discussion seems to be using this principle: arcpy - Change Field Type using Field Mapping for List of Tables using Python - Geographic Information Systems Stack Exc…
Has anyone encountered this error before, and if so, how did you solve it? Should field mapping change to the data type of the output field automatically?
Thank you for any help!
