I am attempting to build an expression in ArcGIS dashboards that will return a few basic summary statistics. It draws from two related Survey123 features.
var fs01 = FeatureSetByPortalItem(Portal('https://arcgis.com/'), 'id', 0, ['*'], false);
var fs02 = FeatureSetByPortalItem(Portal('https://arcgis.com/'), 'id', 1, ['*'], false);
var deliveriesDict = {
'deliveries': COUNT(fs01),
'totalTanks': COUNT(fs02),
'totalFuel': SUM(fs02, 'fuelFilled')
return FeatureSet(Text(deliveriesDict));This code returns the error "Invalid parameter." When I have it return only the dictionary and test it, it returns the expected result. I know I need to return a FeatureSet in order for the expression to work in Dashboards, but the FeatureSet() function doesn't like my parameter. I have also tried the following, with the same invalid parameter error:
var textDict = TEXT(deliveriesDict);
var fs_dict = FeatureSet(textDict);
return fs_dict;
Can someone explain what I need to do to get the expression to return a FeatureSet?
