Software version: ArcGIS Pro 2.9.0
Hi, I am using metes and bounds from deeds and surveys to create property boundaries. I am using CoGo transverse for this.
I create a line feature and enable CoGo before entering the transverse bearings and distances (because I thought that might help my problem). But still no dice.
The problem: How do you make edits to entered bearings/distances once you've closed out of the modify pane? It's as if once you close out of the modify pane, your ability to edit or even SEE the entered data (in it's original quadrant bearing format) is lost. Attribute table shows decimal degrees and editing in the table does not appear to edit the actual direction of the drawing.
All ability to make changes to your lines via the transverse mechanism is gone! This seems ridiculous and I hope I am missing something obvious here. Any help much appreciated!
