I have developed a program to call the "Export To CAD" geoprocessing tool to export the feature classes in personal geodatabase to AutoCAD DWG files. Below are the codes:
private static void ExportToCADByGP(string mdbPath, string fcs, string outputType, string outputFile, string ignorePathsInTables = "Use_Filenames_in_Tables", string appendToExistingFiles = "Overwrite_Existing_Files", string seedFile = "")
int i;
IGeoProcessor gp = null;
IGPUtilities gpUtils;
IVariantArray parameters;
StringBuilder gpMsg;
try
gp = new GeoProcessor();
gp.SetEnvironmentValue("workspace", mdbPath);
parameters = new VarArray();
parameters.Add(fcs);
parameters.Add(outputType);
parameters.Add(outputFile);
if (string.IsNullOrEmpty(ignorePathsInTables))
parameters.Add(ignorePathsInTables);
parameters.Add(appendToExistingFiles);
parameters.Add(seedFile);
gp.Execute("ExportCAD_conversion", parameters, null);
parameters.RemoveAll();
gp.ClearMessages();
gpUtils = new GPUtilities();
gpUtils.ReleaseInternals();
Marshal.ReleaseComObject(parameters);
Marshal.ReleaseComObject(gpUtils);
catch (Exception ex)
if (gp == null)
Logger.Debug("ExportCAD: " + ex.Message);
else
gpMsg = new StringBuilder("Error running Export to CAD");
for (i = 0; i < gp.MessageCount; i++)
gpMsg.AppendLine(gp.GetMessage(i));
Logger.Debug("ExportCAD: " + gpMsg.ToString());
But when I ran the problem, the exception below occurred occasionally:
Executing: ExportCAD
\Export\Temp\F_MAIN.shp;D:\Export\Temp\R_MAIN.shp;D:\Export\Temp\temp.mdb\F_AIRVALVE;D:\Export\Temp\temp.mdb\F_CPI;D:\Export\Temp\temp.mdb\F_FITTING;D:\Export\Temp\temp.mdb\F_FLOWCTLVALVE;D:\Export\Temp\temp.mdb\F_HYDRANT;D:\Export\Temp\temp.mdb\F_MANHOLE;D:\Export\Temp\temp.mdb\F_MANHOLE_PY;D:\Export\Temp\temp.mdb\F_METER;D:\Export\Temp\temp.mdb\F_MISC_PT;D:\Export\Temp\temp.mdb\F_MISCINSTALL_PY;D:\Export\Temp\temp.mdb\F_MSC_LN;D:\Export\Temp\temp.mdb\F_PUMPSTN_PY;D:\Export\Temp\temp.mdb\F_SVCRSVRTNK_PY;D:\Export\Temp\temp.mdb\F_TRTWKS_PY;D:\Export\Temp\temp.mdb\R_AIRVALVE;D:\Export\Temp\temp.mdb\R_CPI;D:\Export\Temp\temp.mdb\R_FITTING;D:\Export\Temp\temp.mdb\R_FLOWCTLVALVE;D:\Export\Temp\temp.mdb\R_HYDRANT;D:\Export\Temp\temp.mdb\R_MANHOLE;D:\Export\Temp\temp.mdb\R_MANHOLE_PY;D:\Export\Temp\temp.mdb\R_METER;D:\Export\Temp\temp.mdb\R_MISC_PT;D:\Export\Temp\temp.mdb\R_MISCINSTALL_PY;D:\Export\Temp\temp.mdb\R_PUMPSTN_PY;D:\Export\Temp\temp.mdb\R_SVCRSVRTNK_PY;D:\Export\Temp\temp.mdb\R_RESERVOIR_PY;D:\Export\Temp\temp.mdb\R_TRTWKS_PY;D:\Export\Temp\temp.mdb\F_TEMP_POINT;D:\Export\Temp\temp.mdb\R_TEMP_POINT;D:\Export\Temp\temp.mdb\F_ANNO_POINT;D:\Export\Temp\temp.mdb\F_TEMP_LINE;D:\Export\Temp\temp.mdb\R_TEMP_LINE DWG_R2000
\Jimmy\F07-SW-16A.DWG Ignore_Filenames_in_Tables Overwrite_Existing_Files
\Export\Temp\template.dwg
Start Time: Thu Dec 2 10:03:49 2021
...Exporting
\Export\Temp\F_MAIN.shp to CAD
.....exporting to
...Exporting
\Export\Temp\R_MAIN.shp to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_AIRVALVE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_CPI to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_FITTING to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_FLOWCTLVALVE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_HYDRANT to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_MANHOLE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_MANHOLE_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_METER to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_MISC_PT to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_MISCINSTALL_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_MSC_LN to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_PUMPSTN_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_SVCRSVRTNK_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\F_TRTWKS_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_AIRVALVE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_CPI to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_FITTING to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_FLOWCTLVALVE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_HYDRANT to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_MANHOLE to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_MANHOLE_PY to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_METER to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_MISC_PT to CAD
.....exporting to
...Exporting
\Export\Temp\temp.mdb\R_MISCINSTALL_PY to CAD
.....exporting to
ERROR 000508: Unable to create
\Jimmy\F07-SW-16A.DWG: Failure During Save
Failed to execute (ExportCAD).
Failed at Thu Dec 2 10:03:57 2021 (Elapsed Time: 8.81 seconds)
\Jimmy\F07-SW-16B.DWG Ignore_Filenames_in_Tables Overwrite_Existing_Files
Start Time: Thu Dec 2 10:09:00 2021
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
...Exporting
.....exporting to
\Jimmy\F07-SW-16B.DWG: Failure During Save
Failed at Thu Dec 2 10:09:03 2021 (Elapsed Time: 3.78 seconds)
But after I ran the program repeatedly several times. DWG files can be exported without error.
Anyone has ideas where the problem is?
