I have set up an ArcGIS Server 10.5.1 on Server A, also ArcGIS Portal 10.5.1 on Server B. Then I have federated Server A to Server B and enabled integrated window authentication on Server B. Now, I need window domain account to login ArcGIS Server.
But the problem is that I need to update one of the map service on Server A. I cannot open connection to Server A on ArcCatalog, also deployed the updated mxd as map service in ArcMap. Are there any ways to deploy map services on window authentication enabled ArcGIS Server? Or I need to disable window authentication temporarily?
