I am building a dashboard with a map that I want to respond to a date selector widget and to restraints applied to the data in the serial chart. Map layers do not appear as possible targets for actions from the widgets. This worked in a previous iteration of the dashboard when I had a map with a 'Feature Layer (hosted)'.
It no longer works after we moved the data to an Enterprise geodatabase and the dashboard to an enterprise portal, and created a Data Store registered with the server, thus creating feature layers that reference the data instead of copying the data. These layers do not appear as possible targets in the actions of other widgets.
Is it possible to use a map layer from a registered data store as a target in a widget action? If so, how can I do this?
Thanks for your help.
Brad
