Good day,
Direction Units and Distances units are currently set at the project level for entering data and at the layer for display by an Arcade expression using a label expression.
Is there any chance that it could be set at the "Record" level by having fields to store them like in the previous ArcMap Parcel Fabric?
We have "records" represented by "Survey Plans" and they are in "Quadrant Bearing" or "North Azimuth" for the direction unit and "Feet" or "Meters" for the distance unit.
Having it at the project is an all or nothing and we need to manually control the units at project for data entering and at the layer using a label expression for display.
For one "survey plan" (record), all the direction and distance units are the same for that record, but the next record could be a totally different. If it was at the "record" level, we could control the input and display of the units better using these fields.
I also think that the scale factor and bearing rotation should be at the record level, so you can re-apply/re-calculate the COGO values from the geometry using "the record" and not set anything manually.
Thank you,
