Hi
I have a spreadsheet with 226 224 records. When I add the the spreadsheet to ArcGIS Pro and add XY, some of the records are no converted to points. I removed the records that were not converted to points and displayed and created a separate spreadsheet. The outstanding records were are displayed and I am able to create the shapefile. When I merge the 2 point shapefiles I get a 'General function failure' error message. If I merge the files in geodatabase the merge works but I get a "could not write value ' ' to output field Restricted" error message. I checked the attribute table and all seems fine.
Is my 'General function failure' error message when I merge outside the geodatabase due the large number of records? If yes how do I make the shapefile available outside the geodatabase.
Bimall
