I am having trouble doing a 1:M join in arcgis pro. But the thing is, when I first tried it worked perfectly when I used the Add Join tool.
For my first try, I joined 182 points (SampleSites) to a related table containing the recurring sample data that is collected at each site (BacteriaSamples). The resulting join has over 6,000 records with the warning (yellow triangle with exclamation mark) about "duplicate rows." Exactly what I wanted.
When I try joining SampleSites to a different table (EcoliRatings_Quarters_Years), it only completes a 1:1 join.
According to the Add Join reference page, "the input table must have an Object ID field to perform a one-to-many join.", https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-join.htm.
My data has an ObjectID field.
Not sure if this matters, but there is one difference between the two tables. The BacteriaSamples is an Enterprise GDB Table. EcoliRatings_Quarters_Years is a File GDB Table. It was an excel sheet that I imported to my Pro project, using the Excel to Table tool. The point file is also in the EGDB.
Somebody please advise, thanks!
Lynn
