I am using MakeQueryLayer_management to read from a Postgres database and populate a table in a file geodatabase.
I have two sde connections for the postgres database. Let's call them user_A.sde and user_B.sde. Each corresponds to a user on the postgres database with the same permissions. Both users can query the table in a third party tool. And both connections can view the table in ArcGIS Pro. And both connections can drag and drop the table into an ArcGIS Pro project.
The problem is when I call MakeQueryLayer_management in ArcPy, one of the users returns the table as expected and the other returns an empty result object. The only change I am making is the path to the sde connection file.
Why would MakeQueryLayer_management return an empty object?
