Im not sure what (if any) would be the best way to go:
- Data coming from PostSQL database
- Publishing the feature datasets to Portal (10.9) from database.
- We have some tables and related tables in database, these can be published as well
- Data in tables changes and needs to be updated periodically
We would like to be able to connect to the table data using excel so non-GIS staff can edit as needed.
- Should we try to set and use excel to connect directly to PostSQL. (ODBC connection?)
- IS there a way to use excel to connect to the published data (Portal)? SO far we have not found one.
Any suggestions, advice, or direction will be most appreciated.
James Armstrong
