Recently I Installed an ArcGIS Enterprise. I have done it before and I use to install portal and configure it with WA. Then we use our proxy server to forward request.
But during recent 10.8.1 installation I got the following Note:
"If you use the ArcGIS Web Adaptor, you need to install and configure it for use with Portal for ArcGIS. To get started, see About the ArcGIS Web Adaptor.
Previously I have been using WA and as the same time set WebContextURL property.
1. My question is, do we need to set WebContextURL property if we configure portal with WA?
2. Are they complementary or a substitute for one another? If so which approach is better?
Mehretab
