I am using Portal for ArcGIS (version 10.4.1), and a web application is deployed in the portal with widgets. In the List layer widget, one of the services is not showing up and when the checkbox is marked following error appears in the console.
Uncaught TypeError: a.isVisbleOrInvisilbe is not a function
at main.js:972
at Object.traversal (main.js:840)
at Object.traversal (main.js:841)
at Object._setTopLayerVisible (main.js:972)
at Object.setTopLayerVisible (main.js:841)
at Object._onCkSelectNodeClick (Widget.js:12)
at HTMLDivElement.<anonymous> (init.js:166)
When I visit the main.js, the isVisbleOrInvisilbe is only available in 3 places as follows.
_setTopLayerVisible: function(a) {
var c;
if (this.originOperLayer.mapService && (c = this.originOperLayer.mapService, 0 < this.originOperLayer.subLayers.length)) {
a ? c.layerInfo.subLayerVisible[c.subId]++ : c.layerInfo.subLayerVisible[c.subId]--;
this._visible =
a;
var b = {};
this.traversal(function(a) {
0 === a.getSubLayers().length && (b[a.originOperLayer.mapService.subId] = a.isVisbleOrInvisilbe())
c.layerInfo.setSubLayerVisible(b)
and further down as follows
visbleOrInvisilbe: function() {
var d = this.originOperLayer.mapService,
h = {};
h[d.subId] = this.isVisbleOrInvisilbe();
d.layerInfo.setSubLayerVisible(h)
isVisbleOrInvisilbe: function() {
for (var d = this.originOperLayer.mapService, h = -1, c = d.subId, p = 0;;) {
h++;
p += d.layerInfo.subLayerVisible[c];
c = d.layerInfo._getJsapiLayerInfoById(c);
if (-1 === c.parentLayerId) return p > h ? !0 : !1;
c = c.parentLayerId
We can clearly see that the function is present, but still, it says it is not a function. What might be the problem?
