Greetings, suffered the following errors ("below") after MS Access tried to open two database files prior to ArcMap, due to my error.
Since I closed out MS Access & shut the application, when now trying to add data into ArcMAP 10.5, both database files post: "Error: Failed to connect to database. An underlying database error occurred. The Microsoft Jet database engine stopped the process because you and another user are attempting to change the data at the same time."
So tried to go back to MS Access and do a DB repair, no chance. Received this error:
"The Microsoft Access database engine has stopped the process because you and another user are attempting to change the data at the same time"
Is there a fix / repair for this 668 meg DB, as the data is very important?
