For my Masters Thesis, I have put together groundwater geochemical maps for an enormous region. The maps contain polygons that I delineated, which reflect areas in the groundwater system with distinct groundwater chemistry. Each polygon was constructed from a few to several groundwater chemistry data points.
I have a variety of data I would like to add to the map. I have developed box plots for the groundwater properties of each of the polygons I delineated, and I have calculated mean residence times and a few other parameters for each of of the polygons, as well. I also have cross sections, well logs, and all the groundwater chemistry data (which is already in the attributes table of each layer file).
I have worked with several online data portals, where you can select data points or areas containing data points and a variety of data for the respective data points will pop up. I am hoping that I can turn my map into something like that where it is somewhat "interactive". My goal is for someone to be able to select one or a few of the groundwater chemistry data points (by clicking them), and a well log, the chemical data, and/or information on the polygons will pop up.
I'm wondering if this is possible to do in ArcMap.
Any help or comments would be appreciated!
