I have a service created in Enterprise 10.8.1 and Pro 2.6 where I have a maximum. visibility range set and no minimum range set. I have loaded this into a Web Map in Portal 10.8.1. For this ONE map I want to remove the maximum visibility range. I have gone into the Change Style Options and slide the slider all the way to the left to show at all scales. However, it still doesn't not display the data at a higher level than what I set in the published service. If I change the minimum with the Change Style Options is reflects that change. Is there a way to override this visibility setting in a web map or what you publish in the service is your only option.
I have SEVERAL other maps set up pointing to this service where I want that maximum range set and I only want to change it for just this one map. My other only solution I have come up with is publishing an entire new service with the visibility range not set, but that seems a little much as they will just eat of more resources on the server for just one map.
