I've regularly used the query function in the Web Appbuilder and sorted my results by different fields as required. Recently I've had a very large dataset, which I couldn't load directly, and instead had to share as a web map layer from Pro. Although I can set up a query to run on this layer, the option to 'Sort' is greyed out. I assume this is something to do with it not being a standard feature layer, but wonder what I can do, as not being able to sort my results is very annoying.
