Hi, I'm working with a client who is having print service problems. Background. They are using ArcGIS Enterprise 10.8.1 which is fully patched. They have a public (anonymous) base map and a public print service. They have many secured map services. It's a new environment and all items are published with ArcGIS Pro.
They have a secured Web App Builder Application with many themes, each being a map service. All but one is turned off by default. If they print to a custom print service then they only see the base map in the PDF. If they turn on a second theme (service) then both services, plus the base map, print. If they turn off either service then it only prints the base map.
The customer and I are using ArcGIS Portal Token accounts. SAML2 accounts give us the same problem.
I went back to basics and created a new Web Map in Portal. I use the default base map, and press 'print with the legend' in the Web Map application (default print service), then I get an HTML output of the base map. I add one secured service, and print, I only see the base map. I add a second secured service, and print, I see the base map and two map services. If I remove either operational map service then I can only print the base map. Adding more than two services always gives me the correct result.
The issue only presents when I print a single secured service over the base map.
All requests are HTTPS, TLS1.2, and fully certified throughout.
Taking a deeper dive. If I use developer tools then I can see that the Web_Map_as_JSON is properly formed. A token is passed with the operational map service. The token is the same as the token that I am using in my header for all requests to ArcGIS Enterprise. It's new, valid and working. If I request two map services then the same token appears in both operational map service requests in the Web_Map_as_JSON.
I have two ArcGIS Servers. One hosts the print service. When I review the logs (in debug) mode, there are no warnings created. The map service(s) are on my second ArcGIS Server Site. Using the debug logging there I can see what I believe is the problem:
When my print service request has one service in it, the request from the print service appears approximately 2 seconds after I request the print operation. I see the message:
"Request user: Anonymous user, Service: {SERVICE1}"
shortly after I see:
"A request was made for service {SERVICE1} but it did not have adequate credentials."
When my print service request has two services in it, the request from the print service appears approximately 2 seconds after I request the print operation. I see the following messages:
"Request user: {User1}, Service: {SERVICE1}"
"Request user: {User1}, Service: {SERVICE2}"
In this latter case, the {User1} user is the correct portal user. Both map services execute normally and I get a PDF from the Web App Build application, or I get an HTML output from the Web Map Print tool. It's just fine.
Looking at the JSON sent via the "Web_Map_as_JSON", the only difference between the print one or print more than one options, is the presence of more than 1 layer IDs. The syntax of the layer ID that doesn't print by itself is the same for both.
I'm lost. All services are coming from the same ArcGIS Enterprise, and nothing 'hybrid'. The sharing is correct, the service work as expected, and it doesn't matter what combination of services (from about 30) that I use, I get the same results.
Thanks for persevering with such a long message.
Scott
