I'm running CityEngine 2016.1.
Whenever I try to run a rule file I get this error (screenshots attached):
Error Message: Unable to create menu item "org.eclipse.jdt.ui.edit.text.java.correction.assist.proposals", command "org.eclipse.jdt.ui.edit.text.java.correction.assist.proposals" not defined
Referred to plug-in: org.eclipse.ui
I don't get this error when running smaller rule files, only a large one. I'm wondering if I'm am missing a plugin that needs to be installed?
Any and all help is much appreciated!
