I am new to Field Maps and am trying to figure out what seems to be a simple issue. I would like to use the form to create a new entry, but have that entry be pre-populated with attributes of the feature that was selected. Here is an example of desired workflow: I have a number of wells in my map. I have also created an editable feature that will house the water levels and date collected for each of the wells in my site along with an accompanying Field Maps form. I would like to be able to click on a well and enter a new water level form entry that has the Well-ID already populated based on the well being clicked.
Is this possible, and if so, how?
Currently I have everything working except I have to manually add the well name to the form. I do not want to "edit" an existing layer since I want to track the changes of water levels over time and have more than just the most recent value per well available. I also do not want to copy a previous entry and and paste a new value because it is ripe for making mistakes (i.e. certain fields may not be properly updated and old data would be inadvertently carried forward).
