I am creating a viewshed analysis application using ArcGIS' Viewshed Sample. My application involves placing multiple markers at specific locations and computing each marker's viewshed on load:
function drawResultData(result) {
var resultFeatures = result.results[0].value.features;
// Assign each resulting graphic a symbol
var viewshedGraphics = resultFeatures.map(function(feature) {
feature.symbol = fillSymbol;
return feature;
// Add the resulting graphics to the graphics layer
graphicsLayer.addMany(viewshedGraphics);
The ArcGIS JS API has an example of scaling markers based on zoom, but it uses a SimpleRenderer that is passed into a FeatureLayer. Unfortunately, my application only uses GraphicsLayers, which do not support renderers.
Is there a way to make Graphics on a GraphicsLayer scale based on zoom? If not, how could I modify the viewshed sample to use a FeatureLayer instead?
