I have a layer in my map (point layer), and I am trying to pull attributes from other layers in the same map (these layers are a combination of point, lines and polygon). I am currently using the below expression to pull through the attributes:
var intersectLayerWoodlandAsset =Intersects(Buffer($feature, 0.5, 'meters'),FeatureSetByName($map,"Woodland Asset"))
for (var f in intersectLayerWoodlandAsset){
return f.FAILURECLASS
var intersectLayerVergeAsset =Intersects(Buffer($feature, 0.5, 'meters'),FeatureSetByName($map,"Verge Asset"))
for (var f in intersectLayerVergeAsset){
var intersectLayerVentShaftAsset =Intersects(Buffer($feature, 0.5, 'meters'),FeatureSetByName($map,"Vent Shaft Asset"))
for (var f in intersectLayerVentShaftAsset){
} The issue I'm facing is that I only want to pull through the field from the given layer when it is only turned on in the map, because there are instances where features in the multiple layers overlap, and I want to be able to dictate which layer the attribute is pulled from.
I'm not sure if this is even possible or maybe I need to re-write the script, but any help is much appreciated!
