Thanks in advance for anyone's help.
I've run into a pretty significant limitation with Portal and am wondering what people are doing to try and work around this problem.
When setting up a collaboration between a Portal and an AGOL, it sounds like you are only allowed to have one of these setup at a time. The problem is that we have multiple clients who use AGOL and need to share data out to them from our Portal. With only one allowed at a time, we can't work with multiple clients at a time in the AGOL / Portal environment so have to default to more basic practices like sharing database files back and forth (not idea!).
https://enterprise.arcgis.com/en/portal/10.7/administer/windows/set-up-an-arcgis-enterprise-and-arcgis-online-collaboration.htm
Does anyone know
1. Why is this a limitation? Is it something that is being developed and fixed?
2. What is the recommended solution here without taking the data offline (siloed into databases), and without needing to upload all the data to our AGOL site (we have portal for a reason....).
Appreciate the help / insights anyone has to offer. Cheers,
