Hey! My DEM (raster) is located in the south of the Netherlands. I would like to make an image based map with the DEM. In further processes I need to have the map with NoData cells as value 0 and the original DEM with values from 1000-1255 (instead of the orginial DEM-values 0 - 1255). Basically, I want to plus 1000 to the original DEM and then assign NoData cells with 0.
Unfortunately, when I'm adding 1000 to the DEM (with raster calculator, or the Plus-tool) the result is distorted. Does anyone know how I can fix this problem? I'm looking on the internet for the answer for a week now 😉
Attached to this post are the original DEM (which I want to sum with 1000) and the result after raster calculator. Maybe it has something to do with the settings of the DEM (see attachments)
Thanks a lot!
