In trying to migrate from 2.x to 3.x, I am trying to update a segment of code and my troubleshoot has ran its limits with Google. I am trying to remove domains from fields in various feature classes below. My error, in particular, comes from the image below where the error I get is the 'NoneType' object is not callable.
Full Code:
# Comments
arcpy.AddMessage("Removing All Domains..." +'\n')
txtFile.write("Removing All Domains..." +'\n')
#Set workspace environment to geodatabase
arcpy.env.workspace = "D:\\WorkSpace\\WebReporter\\Workspace.gdb"
myGDB = "D:\\WorkSpace\\WebReporter\\Workspace.gdb"
#Get list of feature classes in geodatabase
FCs = arcpy.ListFeatureClasses()
#Loop through feature classes in list
for FC in FCs:
#List fields in feature class
fields = arcpy.ListFields(FC)
#Loop through fields
for field in fields:
#Check if field has domain
if (field.domain != "" and field.domain != 'EnabledDomain' and field.domain != 'AnnotationStatus'):
#Print feature class, field, domain name
print (FC, field.name, field.domain)
arcpy.RemoveDomainFromField_management(FC, field.name)
# Get domains that are assigned to a field
domains_used = []
for dirpath, dirnames, filenames in arcpy.da.Walk(myGDB, datatype=["FeatureClass", "Table"]):
for filename in filenames:
print ("Checking {}".format(os.path.join(dirpath, filename)))
## Check for normal field domains
for field in arcpy.ListFields(os.path.join(dirpath, filename)):
if field.domain:
domains_used.append(field.domain)
## Check for domains used in a subtype field
# Comments
arcpy.AddMessage("I got to here..." +'\n')
txtFile.write("I got to here..." +'\n')
subtypes = arcpy.da.ListSubtypes(os.path.join(dirpath, filename))
for stcode, stdict in subtypes.items():
if stdict.get('keys')()()("SubtypeField") != u'':
for field, fieldvals in stdict.get('keys')("FieldValues").items():
if not fieldvals[1] is None:
domains_used.append(fieldvals[1].name)
# Get domains that exist in the geodatabase
domains_existing = [dom.name for dom in arcpy.da.ListDomains(myGDB)]
# Find existing domains that are not assigned to a field
domains_unused = set(domains_existing) ^ set(domains_used)
print ("{} unused domains in {}".format(len(domains_unused), myGDB))
for domain in domains_unused:
arcpy.DeleteDomain_management(myGDB, domain)
print ("{} deleted".format(domain) )
# Comments
arcpy.AddMessage("Removing All Domains Complete..." +'\n')
txtFile.write("Removing All Domains Complete..." +'\n')
