I have a question regarding processing extents, so I'm using processing extents to process a specific area. I use a specific layer as the extents. When I run the process, the model will process shapes that are outside of the specified layer extents. Is this common? Is there a way to rectify this?
There is a image attached that should show what I mean.
(The layer used as the processing extent is the green layer)
Regards,
Justin
