I installed the ArcGIS Runtime SDK for Qt on my Windows machine that already has Qt Creator and Qt 5.15.2 for Android (as well as other Qt versions) up and running.
I created new ArcGIS Qt Quick C++/QML app projects but these fail to compile.
There are missing include files (.h, but also the qml import path).
I found out that SDK .pri files change INCLUDE_PATH and QML_IMPORT_PATH for android on Windows:
C:\Program Files (x86)\ArcGIS SDKs\Qt100.10\sdk\ideintegration\arcgis_runtime_qml.pri
C:\Program Files (x86)\ArcGIS SDKs\Qt100.10\sdk\ideintegration\arcgis_runtime_qml_cpp.pri
These apply C:\ProgramData\EsriRuntimeQt\Qt100.10\ instead of the initial C:\Program Files (x86)\ArcGIS SDKs\Qt100.10\sdk\
However: C:\ProgramData\EsriRuntimeQt does not contain this Qt100.10 folder.
I manually created the folder, and copied the SDK include and android folders to it. This resolves the compilation error and enables running the application.
But this should not be the way to go. What is wrong with my installation?
[The post-installer tool did run, but it gave no kits or options to choose from. It just installs and gives a success message. Older posts refer to this post-installer, but suggest that you have to choose things. Either the post-installer has been simplified in 100.10.0, or somethings went wrong there?]
