Hello!
I was wondering if anyone could assist with custom code for adding an image into my Hub site Header? I wanted to have an image, not just an option to change the header background color.
I found some code samples, but I'm not entirely sure what code to use and where to insert it into the existing code section.
This is what I found. Would this work, or would you recommend something else?
- Enter the following in html page
- Define the css in a stylesheet
If this would work, where in the existing code would I insert this? Or would you recommend something else?
Thanks!
