We have an ArcGIS Enterprise solution set up in house that includes ArcGIS Portal and one ArcGIS Server (version 10.6.1 not federated)
I created a map to be used in the Collector App and the users are receiving the following message.
No certificates found
The app collector has requested a certificate. Choosing a certificate will let the app use this identity with servers now and in the futures. The app has identified the requesting server ... but you should only give the app access to the certificate if you trust the app. You can install certificates from a PKCS#12 file with a .pfx or a .p12 extension located in external storage.
I am not really sure what this message is saying. We have a certificate from Let's Encrypt installed on the web adapter and have auto renewal set to every 30 days.
The message will not allow the user to proceed unless they log out of Collector and log back in. The user has informed me that they are using an Android tablet they purchased from Verizon. (I do not know the exact brand)
I have included a screenshot of the error message.
I am not having any luck when searching this message.
Has anyone else ran across this, or know how to remedy the issue?
Kathleen
