I am using ArcPro v2.7.1 and tried CalculateField on a hosted feature layer which I created and is in my AGOL content. I added it to ArcPro and then tried to Calculate Field on a null column.
Start Time: Tuesday, March 2, 2021 11:38:15 AM
ERROR 160231: Geodatabase System Tables not found
Failed to execute (CalculateField).
Failed at Tuesday, March 2, 2021 2:11:10 PM (Elapsed Time: 2 hours 32 minutes 54 seconds)
Upon looking up the error, I see:
160231: Geodatabase System Tables not found.
ArcGIS Pro 2.7 | Other versions
Description
No geodatabase system tables were found.
Solution
Note:
There is no documented solution at this time.
It calculated 22,404 records out of 71,282 total in the hosted feature layer, before erroring out.
Has this happened to anyone else? Does anyone know if this is a known bug?
