I am trying to use the "Go To XY" tool to find locations within a large satellite image by adding a labelled point to the map. This tool was working well but has recently stopped working. I have restarted my computer and reinstalled ArcMap but it still will not work.
When I first open ArcMap, and before opening any layers, if I use the Go To XY tool in the "meters" then I can use all of the Go To XY functions. However, when I try to use the tool with decimal degrees the tool stops working. Also when I have the map layers open, the Go To XY tool still does not work, even when set to "meters".
Thank you in advance for any help you can provide!
Freddie
