A security scan of an application I maintain that uses several ArcGIS 10.7.1 map services (hosted with stand alone ArcGIS Server, not Enterprise, on AWS server, with IIS as web server) produced this warning for all of the map services:
Oracle Application Server PL/SQL Unauthorized SQL Query Execution
It is possible to view, modify or delete database entries and tables.
I should note that we do not use Oracle dbs in this application (or anywhere in my org). I assume this warning has to do with Server's configuration and Apache Tomcat.
The report suggests this to remediate:
Block unauthenticated PUBLIC access to PL/SQL procedures and applications by adding the following rule to the file "$ORACLE_HOME$\Apache\modplsql\cfg\wdbsvr.app":
exclusion_list= account*, sys.*, dbms_*, owa*
Has anyone encountered this problem? I have never modified any internal configuration to ArcGIS Server.
