I am trying to create a heat map using the values of an attribute rather than the density of points.
I would like to display fine particulate matter level variances to show areas of higher and lower relative concentrations. I have tried using the kernel density tool with similar results to the traditional heat map symbology.
If anyone has advice for how to create a heat map weighted by attribute, it would be much appreciated.
