I and my team are experiencing a problem with a map set up for offline use in Collector. I created preplanned Offline Map Areas through ArcGIS Online, they all packaged successfully and should be ready for use in Collector. However, when the map is first opened, Collector treats the map as live and does not display any available offline areas. Then, if a user creates a custom Offline Area through Collector, all of the preplanned areas display and can be downloaded. This behavior happens for me (the map owner) as well as shared users. The same thing happens in Field Maps. Any thoughts on how to get the Map Areas to display from the start?
In Collector 20.2.2, iOS 14.3
